Sherline edge finders and wobblers
Results 1 to 6 of 6
Thread: Sherline edge finders and wobblers
    Mar 2017
    Default Sherline edge finders and wobblers
    I have my sherline running well under LinuxCNC and I am starting to check around about edge finders and wobblers. It looks like the thing to do is get a 3/8" collet and buy to that size. I bought this to continue my education while I am building the building for a real mill, so I hate to over-buy for something I will likely only use for a year or so. 3/8" shafts can probably be used when I up-grade. Any Sherline, or other micro-mill, owners out there with start up accessories advice? Am I, once again, missing something obvious?
    Feb 2010
    Default Re: Sherline edge finders and wobblers
    I don't have a Sherline (I have a Taig), but yes it appears that most edge finders/wobblers are 3/8" or 1/2" shank diameters. To start out I would buy a manual double ended edge finder like a Mitutoyo 050103. The conical end is handy for finding the center of small holes.
    Once you get more experience with it, you might want a smart probe/edge finder, since you are using CNC.
    Nov 2008
    Austria
    Cheapest option - piece of drill rod with small ballbearing pressed (or glued) at end I have miniature edge finder from proxxon (with 6mm shaft) but in most cases i don't bother with using it since ballbearing is good enough and does not explode even on high speed spindle.
    Member awerby's Avatar
    Apr 2004
    Or you could buy a #2228 1/4" shaft edge finder - $15.40 from Taig: Taig Tools - Desktop Milling Machines and Lathes.
    Feb 2010
    All good solutions, but the Mitutoyo 050103 double-ended center finder is only $19 on Amazon.
    Mar 2017
    going with the 3/8" edge finder and a coaxial indicator. About as cheap as I can get and still have what I need to practice getting it right. Thanks.
