I am making small cnc milling machine.
I have NEMA 23 stepper motor, 10 kg/cm torque, with 1.8 degree step angle, 4 wire bipolar, 3.3 v DC.
TB 6560, 25 pin parallel port Breakout board, TB 6560 micro stepping driver board.
I am using M8 threaded rod for movement directly attached to motor with coupler, No gears, no pully.
My question is how to tune motor for X, Y, Z axis ?
what should be the steps for 1/2, 1/8 micro stepping?
what should be the velocity, acceleration ?
