My Z limit switch was having problems so I bought a new one, replaced it and rewired it correctly. Now it still does not work, it does light up but it does not stop, it goes past the limit switch area and hits the top. Again the limit switch lights up, but the machine does not stop, so now I can not Home my machine.
Also, it had this problem which is why I bought the new limit switch, it is the same switch so that is not the issue.
Any ideas ?
I`m using Mach3, any advice appreciated.
Just to add, the machine was working well for a few years, the previous Z limit switch started to be intermittent, so I replaced it and now it is not working correctly, thanks again for any help!
It has the Leadshine MX3660 too
I have ran into a similar issue, one of 2 things causeing for me it was heat in the PC (full of Dust) and the second was the begining of my board failing.
Does it light the led in the diagnostic screen when you pass a screw driver under it?
is there voltage present on the signal wire at the mx3660? when the light lights and does it go away when the light goes out?
Thank you for replying, I just fixed this last night, I had one of the wires in the wrong input, that`s fixed now & everything is 100%, thanks again for your help!
