Almost ready to wire up
Its a good 500lbs now, all in. not counting whatever i have to stick it on top of.
Not assembled yet, so I'm just gonna show a little tease of the predator version here.
Basically, I've replaced the extrusions on my predator and mini raptor with solid bar
I made the predator ones extra short at 670mm for my machine to give me 400mm/16" travel - guitar maker size.
the gantry cross bar is also replaced with solid.
The mini is the same, just smaller.
If anyone would want this type of upgrade, message me. I want to see if its worth machining a little batch of them. I can make them up to 970mm long.
Note: you may need more x axis motor power... and maybe a stronger table to put it on
