XZero 30x60 Raptor Settings
Results 1 to 2 of 2
Thread: XZero 30x60 Raptor Settings
    Sep 2013
    Default XZero 30x60 Raptor Settings
    After far too long my 30x60 Raptor is finally up and moving. I`m hoping there are some XZero owners running a similar setup that can help me get the best performance out of my machine.
    Setup is as follows:
    382 oz-in Nema 23 steppers (HS23B30A) - 5 A/phase 1.9 mH (8 wire stepper wired in parallel)
    Leadshine MX4660
    Meanwell 48V 10A power supply (NDR-48-480)
    2010 ballscrew on X-axis
    1605 ballscrew on Y-axis
    1605 ballscrew on Z-axis
    Controlled via UCCCNC using a UC300ETH-5LPT
    MX4600 settings:
    Current DIP switches set to 4.95A peak to match steppers?
    Recommended micro step resolution settings?
    Engage 'smoother' switch?
    UCCNC:
    Recommended velocity and acceleration settings?
    I would very much like to change my Y-axis to a 1610 ballscrew to keep the stepper motor RPM down. The machine was supposed to come with a 1610 but was supplied with a 1605 and I was never able to get it resolved with George before he went offline. I'm told the end machining on the ballscrew isn't generic so I have been reluctant in sourcing an EBay vendor that can machine a 1610 screw to George's dimensions.
    Any and all info is appreciated.
    Apr 2015
    Default Re: XZero 30x60 Raptor Settings
    I have nearly the exact same setup but I'm also just finally getting it put back together.
