Need Help! Changing out toggle style F/O/R for rotary switch style
Results 1 to 11 of 11
Thread: Changing out toggle style F/O/R for rotary switch style
    Member Michael82's Avatar
    Nov 2007
    Default Changing out toggle style F/O/R for rotary switch style
    Hey guys I am changing out the clunkie toggle forward /off/ reverse switch with the rotary style for a few reasons 1 it has worn out and is not working properly and 2 when it was working it was hard to flip from each position. I has a wiring diagram from the grizzly G0765 that uses this type setup the lathe I have is the cj0618 7 x 14 I have attached both types of wiring diagrams i am having problems getting the rotary switch wired up the only wire I am concerned with and not sure what or where it goes is the #5 wire in the colored diagram. If someone can take a look at it and explain this wires function it would help . There is a filter board that is a bit different from what's in the colored picture but all the wires that are labeled with a location ( i.e. L2, A+ ) i jave been able to route to the proper location on the rotary switch it is the wires that just have a number rather than a function is where I am having issues... any help is appreciated
    Attached Thumbnails Attached Thumbnails Changing out toggle style F/O/R for rotary switch style-screenshot_20220203-092759_drive-jpg   Changing out toggle style F/O/R for rotary switch style-screenshot_20220203-092942_drive-jpg
    Dec 2003
    Default Re: Changing out toggle style F/O/R for rotary switch style
    What is the switch part No. that you are trying to wire? The DWG is a little indistinct
    I have use the Telemecanique XB2 series in the past, they are made up of separate components and you can make up what style you want fr0m separate parts.
    They are obsolete now, but available from different sources, e.g. ebay 1332484247
    XB2B-BJ33
    Nov 2007
    Quote Originally Posted by Al_The_Man View Post
    XB2B-BJ33
    Part number KEDU ZH-A
    Attached Thumbnails Attached Thumbnails Changing out toggle style F/O/R for rotary switch style-screenshot_20220203-123827_chrome-jpg
    Dec 2003
    That appears to be a simple 3ph reverser, if no diagram came with it, meter all three positions, map them out on paper , then note the new connections that will achieve the same function as the original.
    Nov 2007
    Al can u look at the pictures and tell what the 5 wire ( orange) does ? That's all I think I need all the rest of the wires are labeled with a few exceptions and the wires that are not are easy enough to figure out
    Dec 2003
    Can you post a larger/clearer picture, its hard to make out ?
    Nov 2007
    I have also noticed it keeps popping the fuse when I turn the rotary switch to forward or reverse. The drawing does not show a jumper but the switch has 2 of them
    Attached Thumbnails Attached Thumbnails Changing out toggle style F/O/R for rotary switch style-16439316072148718007559682664011-jpg
  8. #8
    Dec 2003
    The function of the orange conductor is hard to tell, the details of the board it is connected to would need to be known, there also looks like it might be associated with the white one that runs with it?
    Nov 2007
    Quote Originally Posted by Michael82 View Post
    This is page 61 in the owners manual of the G0765 7 x 12 mini lathe on grizzly website down at the bottom of the page you can see the owners manual and parts list
  10. #10
    Nov 2007
    Since I couldn't get the rotary switch to work I went back to all original and now I keep blowing fuses and the relay sparks does anyone know what could have happened? I may have shorted something trying to work out the rotary switch where should I start to look ?? Power resistors??
  11. #11
    Nov 2007
    This is the original wiring diagram
    Attached Thumbnails Attached Thumbnails Changing out toggle style F/O/R for rotary switch style-20220206_193306-jpg
