Need Help! New Motor to SIEG X3
Results 1 to 3 of 3
Thread: New Motor to SIEG X3
    Member X3Miller's Avatar
    Sep 2021
    Exclamation New Motor to SIEG X3
    I have just bought me a SIEG X3 Milling Machine, but it just got 1800 RPM. Can`t mill Aluminum.
    Is there anybody that can tell me if there is a replacement motor to this machine that have around 10.000 RPM and what I have to do to get this RPM.
    Must be 220 Volt.
    Jul 2009
    Default Re: New Motor to SIEG X3
    Don’t limit yourself to 220 v motors only.
    You’ll be much better off getting a three phase motor and a variable frequency drive.
    Although the spindle bearings on the X3 may not do very well with speeds your looking to run.
    Jan 2018
    United Kingdom
    You need to look into changing pulley ratio's or a belt conversion if geared. You'd prob blow spindle bearings above 6k rpm.
    You can mill ally at those speeds, just a little bit slow. High DOC with lower SFM and feed. (unless using small size cutters).
