So the breakout board has a relay for the spindle but it's only rated for 30 volts 10 amps DC. And the switch gets power up to a hundred volts.
The relay will handle 10 amps at 110 volts ac but I would have to bypass the fault saftey for that to work. How have you guys done this?
Name brand DC relays that can handle a hundred volts at 10 amps are expensive I might as well upgrade to a brushless motor and controller at that point
