Project numbers
Results 1 to 4 of 4
Thread: Project numbers
    Registered Martin1984's Avatar
    Sep 2007
    Offenau
    Hello
    We work with the version 18.18 and 19.
    Does anyone know how it’s possible to link project numbers (the file) in order that the project number of both versions would be automatically counted?
    Regards
    Martin
    Registered fraenky64's Avatar
    Dec 2002
    Hello Martin
    Do you mean the file projet.num that is increased at 1 with each project?
    Then it’s easy.
    Place the file into a Folder in network.
    Refer to this file in the both versions, e.g.
    WNCDATAPRO=X:\wncconf
    The file “projet.num” has to be there.
    Done
    Regards
    Frank
    Sep 2007
    Offenau
    Hello
    Can I also declare the path of the V18 in the WorkNC version 19?
    Could you tell me where I can find the settings?
    Regards
    Martin
    Dec 2002
    Hello Martin
    Just refer to the same folder as I wrote above in \client\instsite\Environ.cfg.
    In our case the file is placed into a folder in the network
    X:\wncconf\projet.num
    There stands in environ.cfg then
    The folder declares it after the file projet.num is searched.
    If the same folder is refered to in all versions, it’ll be always incremented.
    Regars
    Frank
Project numbers
Project numbers
