Vacuum seal gasketting
Results 1 to 8 of 8
Thread: Vacuum seal gasketting
    alkibum's Avatar
    Jan 2019
    Default Vacuum seal gasketting
    Hello,
    Hope I can ask someone with this gasket a question.
    We bought an new industrial cnc in December, (why arent I asking them? Another issue...)
    We applied a gasket they recommended around each vaccum zone. The gasket they recommend sounds like normal on here where it sits a bit above the phenolic then compresses with the vacuum.
    Well thats all well and good, but here is our issue. When we for example want to cut from say zone 1 a piece to fit right in there. We would then turn off the other zones, well that compression somes into play and raises that side of the table and messes up my cuts.
    Anyone else have this problem, or am I extraordinarily lucky? If so whats the slution, no gasket?
    Thank in advance
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Vacuum seal gasketting
    Hi Alki - How's does compression raise the table? maybe a photo to explain? or more words?? Do you mean the job is sitting on the uncompressed seals? Peter
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    He's got an MDF spoilboard with a multiple zone plenum underneath it, with each zone having it's own seals/gaskets. When he turns the zones off, there's no vacuum to compress the seals in those zones.
    UCCNC 2017 Screenset
    Member CitizenOfDreams's Avatar
    Nov 2012
    There should not be a gasket in any area where the vacuum is off. If you turn a zone off, either remove the gasket from that zone or keep your parts/spoilboards away from the uncompressed gasket.
    Are you using a single large MDF spoilboard that covers the entire table? In that case, you can keep the vacuum on in all zones and cover the unused portions of the spoilboard to seal the vacuum.
    alkibum's Avatar
    Jan 2019
    Hello thank for the replys,
    Correct: He's got an MDF spoilboard with a multiple zone plenum underneath it, with each zone having it's own seals/gaskets. When he turns the zones off, there's no vacuum to compress the seals in those zones.
    alkibum's Avatar
    Jan 2019
    So what do you guys do with this situation? You cant remove the gasket without taking the entire spoilboard off, I can block out areas and leave all the vacuum on, but that defeats the purpose of the vacuum areas.
    Does anyone have any recomendations on what they do in this situation?
  7. #7
    alkibum's Avatar
    Jan 2019
    What do you think Ger21? I was thinking to cut my mdf into the sections, but if I do that when I have a part bigger than my section Im back to bocking it out.
    Thanks again for any thoughts
  8. #8
    Aug 2005
    Cut thin plastic sheets roughly the same size as the unused zones. Use them to cover the unused areas of spoil board. You still have to draw down those areas, but you won't waste vacuum and you won't distort the spoil board. Reject vertical grade laminate works fairly well. Or, in a pinch, construction plastic sheeting works.
  9. #9
    Mar 2003
    Shelby Township
    I agree with Marv, but I'd use something a little thicker than laminate, as it will usually seal better.
    One big zone and cover the unused part of the table, rather than separate zones.
  10. #10
    Nov 2012
    The best strategy depends on the size and variety of the parts you are making.
    One option is to make several spoilboards - one for each common stock size. At our furniture factory, we have dozens of spoilboards for each CNC machine. When we design a new part, we also design and make a dedicated spoilboard to go with it.
  11. #11
    alkibum's Avatar
    Jan 2019
    OK thanks all for the tips!
