Cutting drawer liner material with OTC, Holddown solution needed
Results 1 to 2 of 2
Thread: Cutting drawer liner material with OTC, Holddown solution needed
    Member Volkhard's Avatar
    Nov 2011
    Germany
    Default Cutting drawer liner material with OTC, Holddown solution needed
    I am considering fabricating a small series of partially irregular shaped drawer liners.
    I am planing of using a regular CNC Maschine equipped with an oszilating tangential knife. Coming from the woodworking side of things, machine, OTC etc are less of an issue. But how can I get the material down to be cut? Depending on the material there might be more or less friction. Double-sided tape is not an option I would consider. Any ideas or even better experience?
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Default Re: Cutting drawer liner material with OTC, Holddown solution needed
    A vacuum table sounds like it might be a good option.
