Newbie Can anyone recommend a tool for shaping cricket bats from English Willow?
Results 1 to 4 of 4
Thread: Can anyone recommend a tool for shaping cricket bats from English Willow?
    Member SystemX17's Avatar
    Feb 2019
    Default Can anyone recommend a tool for shaping cricket bats from English Willow?
    Trying to get an easier to work with finish on a cricket bat design. Just not sure if I should be using a bull nose or flat or what sort of bit to get the best results. Anything rounded seems to leave too much in the way of grooves to smooth out. Have also tried horizontal movement but the cuts seem to add additional problems with the spine.
    Attached Thumbnails Attached Thumbnails Can anyone recommend a tool for shaping cricket bats from English Willow?-79270630-6550-4fb4-966e-f93ae194ca25-jpg   Can anyone recommend a tool for shaping cricket bats from English Willow?-b31b69bd-635c-4aea-99ae-555a99a9e542-jpg   Can anyone recommend a tool for shaping cricket bats from English Willow?-dc672b69-f526-483e-9c18-1866473607d8-jpg
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Can anyone recommend a tool for shaping cricket bats from English Willow?
    Hi X17 - If you have a 3 axis machine definitely not a flat bottom tool. I make hydrofoils and use a 1/2" round tool. A veining router bit with a 1.0 - 0.5mm stepover and that cleans up very easily. Peter
    Attached Thumbnails Attached Thumbnails Can anyone recommend a tool for shaping cricket bats from English Willow?-wing-1-jpg   Can anyone recommend a tool for shaping cricket bats from English Willow?-sting-foil-jpg
    Member awerby's Avatar
    Apr 2004
    Use as large a ball-nose cutter as will fit in the spindle. If the cusps between passes are too large, space the passes closer together. Cut lengthwise, with the grain.
    Feb 2019
    Thanks guys! Will have a test of both solutions
