Good tool for solid surface
Results 1 to 7 of 7
Thread: Good tool for solid surface
    Member Biggs427's Avatar
    Feb 2016
    Default Good tool for solid surface
    It is for my DIY CNC with a (8000 to 25000 rpm router)
    I tried several type of cutters and what works the best so far is a 4mm chinese 2 flutes upcut with TiN coating. Helix looks 45deg. This cutter performed better than my carbide 1/4 2f upcut spiral or straight cutter.
    Since there's no such thing as a "cutter datasheet" for chinese cutters, I set my chipload to 0.005 and the result is ok; not stellar but ok.
    What would be the best tool to cut solid surface (Corian) ?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Good tool for solid surface
    I cut a lot of Corian with a Vortex 4233.
    https://www.vortextool.com/index.cfm...937FBE733908B4
    UCCNC 2017 Screenset
    Jun 2017
    I cut a lot of modified solid surface I had great success with 8mm down shear cutter for rebates and 1/4inch 2wing comp cutter
    Sent from my Le X820 using Tapatalk
    Jun 2017
    Also set rpm to 14000 and feed rate to 12m pm
    Feb 2016
    Thanks thanks both of you for the tips.
    I have some low helix upcut and compression cutters. I will do some testing tonight.
    My machine can only cut at 8m/min (315IPM). I assume I should I adjust the rpm to keep the same kind of chipload?
    Mar 2003
    Shelby Township
    Imo, there's no reason to use a downcut or compression bit with solid surface, because you don't have edge chipping issues.
    If you can cut at 300ipm, I'd start at 14-15,000 rpm. 1/4" depth with a 1/4" bit.
  7. #7
    Jun 2017
    Quote Originally Posted by ger21 View Post
    Yeah your probably right, I didnt seem to get much chipping with 100percent acrylic solid surface or Corian I know a 2flute 1/4inch is pretty much the cutter to use, but with modified solid surface I did get a lot of chipping especially on rebates. This is just my experience.
