Newbie advice on the full process
Results 1 to 4 of 4
Thread: advice on the full process
    Aug 2016
    Default advice on the full process
    Howdy!
    I'm looking for advice on tooling for my companies new cnc router.
    we have a 3kw hsd spindle with an er 25 , collects in 1/2 3/8 and 1/4
    I'd like to be able to complete each piece in two cuts/ a single tool change
    a little about the process
    We make airplane propellers out of maple, starting from a blank about 5.5 x 7 x 65 inches, approximately 60 percent of this wood is removed in the production process.
    I will still be removing as much of the bulk material as I can with a bandsaw, but have been mostly looking at the biggest tool I can run for my roughing pass, which I plan to run along the length of the propeller blade, stepping down its height. the final pass I plan to have run up the propeller blade using probably a 1/4 end mill.
    I'm interested in something like an indexable endmill for roughing but I cant find anything like that for wood, just like the idea of replaceable carbide insert, as I wouldnt have to worry about sharping as much for the roughing tool.
    Everything I can find to read only tells me the basic types of bits and other basics, but i'm wondering how you size things to the spindle you have other than trial and error?
    any ideas/suggestions/questions are appreciated!
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: advice on the full process
    UCCNC 2017 Screenset
    Aug 2016
    Quote Originally Posted by ger21 View Post
    fantastic! is there a way to calculate/ a general rule/ to determine how deep of a cut a spindle at a given kw can make? Kind of need to make the safe play with cutters for now as I dont have the capital to be trying a bunch out.
    Thanks for the input!
    Mar 2003
    Shelby Township
    There are a lot of factors involved, including type of tooling, material being cut, workholding,....
    It's also a combination of depth and feedrate. The deeper you cut, the slower you need to go.
