Newbie Anyone use down cut bits for wood cutting... - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Anyone use down cut bits for wood cutting...
  1. #21
    Default Re: Anyone use down cut bits for wood cutting...
    Not the same brand but I did find this 1/8" downcut with an 1/8" shank on EBay. Seems deccent quality! https://www.ebay.ca/itm/151926815022. I should add that the seller said it would work fine for wood, which is how I intend on using it.
  2. #22
    Oct 2007
    canada
    yah thats a possiblity...was hoping for a 2" OAL thats what all of my up cuts currently are
  3. #23
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    .i would like an 1/8' down cut as well with an 1/8 shank...doesnt seem to exist
    Most of the major router bit manufacturers don't make 1/8" shank bits, because handheld routers don't have 1/8" collets.
    Ebay is your best bet for 1/8" shank tools. You'll pay a fraction of what you'll pay anywhere else.
    UCCNC 2017 Screenset
  4. #24
    I noticed that Lee Valley is offering 1/8" down cut bits for dremels, I assume they are fine for CNC routers. Not sure on the OAL, but here's a link Mini Downcut Spiral Bits - Lee Valley Tools
  5. #25
    Mar 2003
    Shelby Township
  6. #26
    Looks like the same seller as my earlier post with a volume discount. Good price!
  7. #27
    Jan 2007
    I found a downcut bit was my only way to run cutting profiles in thin sign work in 1/8" PVC sheet (Sintra board). Its a really flimsy sheet and my vacuum couldn't keep the sheet flat with an upcut. The upcut force would lift the sheet from the spoilboard and screw up the cut accuracy. Are there compression bits that would place the compression center in the middle of such a thin sheet?
  8. #28
    Oct 2007
    canada
    ordered the 1/4 yoniko and will order an 1/8 and 1/6 from fleebay...to save my sanity from sanding
  9. #29
    Member Biggs427's Avatar
    Feb 2016
    Quote Originally Posted by ger21 View Post
    The box joint pics I posted earlier were done with a Yonico bit from Amazon.
    Gerry, what chip load, rpm, feed and DOC are you using in hardwood with your Yonico down cut?
    I have a 7/32 3 flute down cut but can't find anywhere the specifications and Yonico doesn't seems to bother when I mail them...
  10. #30
    Mar 2003
    Shelby Township
    Anything under 1/4", I keep my depth of cut to no more than the tool diameter.
    Feedrate depends on what you're doing, could be anywhere from 75ipm to 300ipm. 12,000-18,000 rpm.
    With a 3 flute, keep the rpm lower, and the feedrate higher.
  11. #31
    Apr 2009
    Lately (which is past 3-4 years), for wood, I use single-edge endmills almost exclusively for most any tooling 1/4" or less. Creates larger chips, and ejects them a lot better. Plus, you can run your spindle at higher speeds, where you'll have more HP...
  12. #32
    Feb 2016
    Running at higher speed would help the speed control on my router to keep up...
    I saw single flute dow cut in a catalognat work. I think I'll order one to try. I think it's FS Tools. Are these good cutters?
    My new router is supposed to have 2hp but at lower rpm my old 1hp Makita had better speed control so it "felt" like it had more power at low speed...
    I really need to complete my PID but sometimes life gets in the way.
  13. #33
    Mar 2003
    Shelby Township
    Yes, FS tools are good, and made in Canada.
    Probably not the cheapest, though, but nothing is, when you live in Canada.
