HSK Tooling Wont release
Results 1 to 2 of 2
Thread: HSK Tooling Wont release
    Aug 2007
    Default HSK Tooling Wont release
    Hi Guys,
    I have a Fimec ES929 HSK 63 spindle with less than 100 hours use which I allowed to bottom out on some MDF for a couple of minutes.
    When I removed the slightly discoloured tool holder and cleaned it up there was a bit of greasy residue in the bottom the tool holder cavity which I hadn't noticed before
    I tried to clean out and cool the lower end of the spindle- yeah I know now a dumb- to ensure the bearings were OK.
    Since then I have inserted another tool only to have it seize up in the Spindle nose.
    So far not wanting to damage anything with the knochrometer I have dismantled as much of spindle as I can but still can't dislodge the tool holder
    Any suggestions would be greatly appreciated in an effort to remove the Tool holder and prevent any furthe issues .
    Pete
    Attached Thumbnails Attached Thumbnails HSK Tooling Wont release-side-jpg   HSK Tooling Wont release-tool-holder-jpg   HSK Tooling Wont release-top-jpg
    Mar 2008
    Default Re: HSK Tooling Wont release
    This happened to mine. Wood pitch built up. The solution was the knockulator. I held in the tool change button and GENTLY tapped the holder. It popped out with a vengence. Put a pad or some other way to catch it.
