Need Help! 20CrMnTi welding shaft build up
Results 1 to 2 of 2
Thread: 20CrMnTi welding shaft build up
    Mar 2013
    Question 20CrMnTi welding shaft build up
    Hi guys !
    I need to build up a splined shaft from 52mm(top of spline is 60mm) up to 70mm O.D over a length of about 110mm then, anneal it, bore it 50mm I.D, turn it, carburize it, heat treat it and grind it for a bearing fit... 20CrMnTi Material is close to SAE3115 or 20MnCr5.
    I have an AC stick welder and my welding buddy is a TIG welder by trade..
    What welding/filler rod should I use for this job ?
    Thanks very much !
    Mar 2013
    Default Re: 20CrMnTi welding shaft build up
    Up !!!
