12V HF HV Tig Box Design?
Results 1 to 2 of 2
Thread: 12V HF HV Tig Box Design?
    Oct 2017
    Default 12V HF HV Tig Box Design?
    Hi Guys, New here i have used the search function but maybe i am not using the right search words, Has anyone made a 12volt high frequency tig welding box? i have found 240volt models but if there is a 12-24v model i would much prefer to build this
    Member handlewanker's Avatar
    Sep 2006
    Default Re: 12V HF HV Tig Box Design?
    Hi........I've seen a few HF addons to make a stick welder capable of doing Tig without having to scratch start simply with a 12 volt car ignition coil and the respective HF blocking capacitor.......there's quite a few DIY circuits on Pinterest if you are onto that site.
    Ian.
