Looking for manufacturer that can fabricate large ABS panels
Results 1 to 3 of 3
Thread: Looking for manufacturer that can fabricate large ABS panels
    Member PinXvol's Avatar
    Jan 2025
    Post Looking for manufacturer that can fabricate large ABS panels
    I am looking for help in machining large custom abs panels for our machine.
    Each set has 24 different parts, the largest one have an overall dimension of 1550mm x 930mm x 18mm, and the thickest part having a thickness of 70mm.
    There is a preference for manufacture in Canada, but rest the world is fine as well.
    If you or you know someone that has the capability to fabricate, please let me know.
    Thanks in advance
    Default Re: Looking for manufacturer that can fabricate large ABS panels
    DM
    Member Laserfeign's Avatar
    Aug 2024
    I work for a company in texas called Anchor Fabrication. We cut 4 inch plates for train cars. Look it up they might be able to help you out.
    Quote Originally Posted by PinXvol View Post
    Thanks in advance
    mournburnet's Avatar
    Sep 2024
    Thanks in advance
    Can I communicate with you by email?
