Tailstock Problem
Results 1 to 4 of 4
Thread: Tailstock Problem
    Perich1978's Avatar
    Feb 2023
    Default Tailstock Problem
    Good morning
    I have this tailstock installed on a REMCO cnc. i want to buy a new one or find the gears, but don't know the brand or model number. I'd appreciate some information about it.
    Tailstock Problem-tailstock2-jpg
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Default Re: Tailstock Problem
    Hello Perich1978, the photo that you uploaded is not viewable (at least by me). As far as I can tell, you followed the correct procedure, but somehow gremlins have made an appearance.
    Perhaps you'd like to try a 2nd upload?
    Administrator burs's Avatar
    Apr 2019
    Germany
    Quote Originally Posted by RaderSidetrack View Post
    It should now be visible to all. I have uploaded it again.
    Jan 2013
    england
    Quote Originally Posted by Perich1978 View Post
    Good morning
    Looks like the tailstock is mounted on a support bracket to raise the centre line. Perhaps if you removed it and gave it a clean, you may find some stamped or casting numbers to give you a clue about it's origins.
    The quill is missing for sure, but the winding handle seems to be in place, maybe remove it and you'll find it is a gear inside.
    A tailstock quill usually has a rack gear cut along it.
    I don't recognise it though, sorry.
Tailstock Problem
Tailstock Problem
