hello sir, I have this item, if you need it, contact me
Does anyone have an pulse coder for sale? I need a correct one.
Pulse coder fanuc A860-0300-T003 3000P
What is the difference between oulse coder A860-0300-T003 3000P and A860-0320-113 3000P?
Is the difference only in the mechanical part and installation or is there something else?
Could the A860-0320-113 3000P (ac servo motor) replace the encoder A860-0300-T003 3000P (dc servo motor) if were to rebuild the bracket and coupling?
I would replace only the encoder, and the motor would remain the same that was on the machine. The only thing is that my motor is DC, and the other is AC whose encoder I want to install. Is there any connection, or can it be installed?
Does the cable fit or does it have to be modified?
