I think what you are looking for is a Dial Test Indicator (DTI). Normally the stylus is rotatable through 180 degrees or a bit more. 0.001mm? That's pretty high resolution, lab grade hardware. 0.01 - 0.02mm is reasonable for shop use.
https://www.amazon.com/s?k=dial+test...f=nb_sb_noss_1
