hy do you need drawings for those pictures only ? or you wish for drawings on a regular basis ?
only by seeing the picture, is not possible to tell if actual hole is 8mm or not ....
if you are interested, i can digitize from picture / kindly
Hello,
I am looking for someone that can create drawings for gantry plates and corner brackets. The attached picture show the shape of what I am wanting, These plates/brackets are to be used with 8mm lead screws and I am wanting to use 16mm ball screws, so the C beam I am using is different and the mounting holes at the to of the plates and on the sides of the corner brackets have to be different.
Thanks,
Donavon
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
The picture is for reference, the parts I need will look like these but the hole placement and the overall dimensions will change due to using different C Beam. Attached is what the C Beam looks like that the pic is designed for and the new C Beam.
Currently I only need this set of drawings.
okey .... pls, what do you wish to change in that image ? dxf format is ok ?
