That's unlikely to be made by a CNC machine directly, although a CNC mill might be involved in making the original, which is then molded and cast to produce multiples. There's no single machine that gets you all the way there. Instead, you'd need to set up an industrial process which starts with prototyping, then proceeds through molding, casting, metal-finishing, plating, and assembly.
