Hi....I've gone down this path as I want to mess with a small CNC router for fun carving and engraving etc but after buying a 3018 (still in the box) I decided to build one to my own design (instead of replacing the light components) with linear rails and ballscrews all round and a 500 watt motor all running on Mach 3....... basically beefing it up to make it perform better but still only wanting to carve wood and plastics etc.
I think the frame of the 3018 design is way too weak and flimsy to cut metal or make anything that requires dimensional accuracy.
At the moment the build is 75% finished with the mechanicals and is at the Z axis stage.
This is not a case of making it cheaper than the buy in model but as an improved construction with more sophisticated components etc while still maintaining the 3018 envelope.
There are a lot of differences with the various models mainly in the configuration of the framework as it' s a big boy's Meccano set after all and is a bolt together extrusion design with a very small motorised spindle of approx 200 watts for the cheapest and a funny brass tool bit holder as opposed to an ER chuck.........you definitely only get what you pay for and it runs on GRBL not Mach 3..
Upgrading to a 500 watt brushless motor will cost A$150 approx.
Ian,
