- Need A Quote- LOOKING FOR HEAVY DUTY CNC VERTICAL MILL
Hello All,
I am very new to the CNC milling world, and i need some help locating a piece of equipment that will fit my needs. We will be milling pockets in 2"x7"x187" flat bar. I am in need of something that is CNC that uses somewhat updated systems and can handel that size of material.
that weight on it will be about 700LBS. We are a fab shop so i do have the ability to make tables with rollers to help accomidate the weight. Need something that can be used heavily. Any recommendations are greatly appriciated.
Thank You in advance,
Josh Parker
AMFI
- You may not post replies
- You may not edit your posts
Forum Rules
