wanted step driver MS-2H057M
Results 1 to 6 of 6
Thread: wanted step driver MS-2H057M
    Member rocabig's Avatar
    Dec 2005
    Default wanted step driver MS-2H057M
    My 12 year old excitech 9060 step driver just failed and am trying to find a replacement
    any help will be much appreciated
    im in brisbane
    the driver is a MS-2H057M from shaphon Co ltd usa
    apparently they are not made anymore
    Dec 2012
    Mexico
    Default Re: wanted step driver MS-2H057M
    Hello.
    A simple googling gave me this:
    https://spanish.alibaba.com/product-...117918185.html
    https://es.aliexpress.com/i/32842902460.html
    Regarding a replacement it should be fairly simple as it is a 48V/3A drive. Just check for the number of step configuration that you require. It is possible that most of the new ones if not all have your configuration.
    Regards.
    Dec 2005
    thank you
    i did the googling and everything seems fine right up to when you go to order/pay when they say 'this item is not avalable'
    thanks again
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by rocabig View Post
    thank you
    thanks again
    Is this one what you need?
    https://www.paycnc.com/ms-2h057m-mic...ver_p2497.html
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2005
    Quote Originally Posted by cncmakers001 View Post
    i have been told the DM542T will do the job
    i have one on order
    thank you everyone for all your help
    May 2015
    The DM542 will do the job. I quite like them. If you are really stuck and sick of waiting I'd have one here at Acacia Ridge, Brisbane.
    Rod Webster
    www.vmn.com.au
