up
I need at least one of these toolholder blocks. Do anybody know where i can found these?
- Parameters for Colchester 2000 with 0-TC control and 8 station Duplomatic turret
- Need Help!- #2057 Turret Clamp Error(A9.1) and #2018 Turret Run Alarm (A4.2)
- Converting my Engine Lathe to an 8-Station Turret Lathe!
- Dual Station Vise On The TM1P Or Single Station Vise Options
- Sources for USED Hardinge T42 (12-station turret) SG-type Tooling
up
dear sir i have the same machine yamck1 with control fanuc 10 t and i have a problem with the parameter can u help me
I can try.. what kind of problem?
the parameter no 9108 in my machine is 11100000 but this make measure key is not working for measure tool offset geometry so i want to know the parameter no 9108 right one
Are you sure that you do it right way? You first write axis what you measure. Z or X and then value and after that push softkey measure? If you write only value and measure, it dont works. I can check parameter in this weekend. I have all parameters in paper.
thank you sir for replaying and its working now i write x0 then push measure and its working and i will be thankful if u send to me ur email or whatsaap to contact with u thak you very much
dear sir i have an error called " non mask interrupt "how can i solved it my machine is yam ck1 control fanuc 10 t
Up!
