- Anyone know where I can find a tailstock for an Enco 111-3100 gear head lathe?
Hey all-
I have a 1908's vintage Enco 111-3100 lathe. was drilling out some aluminum with a 1in drill, and the stops in the barrel at the end of the MT3 taper made a crunching noise and the drill spun. The stops got taken out, and when I took it apart, the barrel and the acme thread both bent slightly, enough that I had to use an arbor press to get the things out of the casting. Anyone know where I could lay hands on one of these, or at a minimum, the 1.5 inch diameter barrel with a 3/8 acme thread in it that I could retrofit? Failing that, does anyone here know what other model of lathe's tailstock barrel is 1.5 inches (or near enough I can skim it to 1.5) and has any kind/size of acme thread inside it? Been looking for 2 months everywhere I can think of, and so far, nothing.
Any help would be greatly appreciated.
-Farasien
- You may not post replies
- You may not edit your posts
Forum Rules
