Just In CNC for medical Screws
Results 1 to 6 of 6
Thread: CNC for medical Screws
    Member Omar1409's Avatar
    May 2019
    Default CNC for medical Screws
    Hello
    Im looking for a CNC machine for medical screws and im confused between DMG mori Sprinter 20-8, Tornos Evo Deco 20 and Haas
    DMG and Tornos are expensive and Haas is affordable,
    my desired Screws
    Diameters between 2 and 10 mm
    Length between 4 and 100 mm
    Material Titanium grad 5
    can you please recommend us a machine from the 3 of the above or even other brand, The machine must be able to do self tapping Locking screw so that it can be screwd in Bone and Plate.
    Thank you
    Attached Thumbnails Attached Thumbnails CNC for medical Screws-self-tapping-locking-screws-diameter-5mm-700-a   CNC for medical Screws-68935-13799893-jpg
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: CNC for medical Screws
    Hi - You may be able to machine them but you won't be able to forge the socket? They are rolled threads to improve strength, cut threads are not as strong. Plus don't they have to be certified? Why don't you buy them? cheaper then buying a mill? Peter
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by peteeng View Post
    The threads are done by thread whirling and the socket what ever shape are cut on the machine also here is a video
    https://www.youtube.com/watch?time_c...&v=FAd9NyB-6ko
    Mactec54
    Jan 2005
    Quote Originally Posted by Omar1409 View Post
    Hello
    my desired Screws
    Thank you
    You are looking at the wrong machines, you want a swiss type screw machine for these parts, here is just 3 of the main manufactures of these multi axes machines, your parts could be made on other multi axes machines but would not be as efferent as this type of machine
    Citizen
    Brother
    Tsugami
    Mactec54
    Jul 2018
    dum dum
    Thks mactec - haven't seen broaching like that before, very cool. Peter
    Member tjm229's Avatar
    Jun 2019
    Post Re: CNC for medical Screws
    Hi
    I would go with either a Tornos, Citizen L20 or Star SR20 if you want to get into the medical sector. Parts are required to be close tolerance from my own experience with excellent surface finishes. A sliding head machine (Guide Bushed) will give you the best shout at achieving this. Also, with the amount of tool stations available on these machines you can swith from part to part quickly with minimal changeover times.
    Have a look ath the spec of sliding head machines we run at our company here for more info:
    https://www.mmturnedparts.co.uk/plant-list/
    Hope this gives you a bit more insight.
    Kind regards
    Tim M
