This might be a place to start https://www.cnczone.com/forums/newly...c-tormach.html
Any sources, methods, and advice, on getting a CNC mill? DIY kit is acceptable, or link with parts to order.
I need it for creating small prototypes, no bigger than 20x20x20 cm. (NOT engraving please)
It should mill Aluminum with minimum of 0.005" tolerance.
< $1000 price.
Any help appreciated!
Jim Dawson
Sandy, Oregon, USA
$US1000???....you will be very lucky to find such a beast.....if you have the mechanical skill and knowledge + machinery to build it the only course for you is to build one...….otherwise $1000 only gets you a toe in the door.
My suggestion would be an all welded moving table tubular steel build design.....that's a gantry type with the gantry fixed and the table moving.
Ian.
