- Fanuc A06B-6077-H111 power supply. 49Amp. 13.2Kw schemes
Hi all:
I have a Fanuc A06B-6077-H111 power supply. 49Amp. 13.2Kw that occasionally gives the error 04.
This occurs when starting or operating normally when the spindle motor stops. I already changed the thyristor module for short circuit between the gate and cathode. I need the schemes of this module if someone is so kind to provide them, since I can not find them anywhere.
Thank you.
- You may not post replies
- You may not edit your posts
Forum Rules
