- New Product- Priminer V6L
Priminer V6L
Hello everybody.
I want to know if someone knows this brand Priminer, I'm looking for a machining center and they have some machines but I can't find any reviews.
Does anyone have one? Can you give some inputs about this?
CNC SIEMENS 828 3D technical specifications DELTA CENTER V6L
CNC control SIEMENS 828 3 D
Table dimensions mm 750 X 400 MM T-slots 14 x 3 x 125 mm
Maximum table load kg 350
X/Y/Z stroke mm 600mm / 400mm / 450mm
Distance spindle/table surface mm 80-530
Distance spindle Center / Z axle cover 435 mm
Spindle retainer for SK 40 / 120 mm
Spindle speed RPM 12,000
Spindle motor kW 20 SK 40 7/15
Number of tools 20.
Max tool diameter 80 mm
Max tool diameter (without adjacent tools) 80/125 mm (next releas)
Max tool length mm 280
Maximum tool weight kg 8
48 m/min rapid traverse working feed mm/min 1-10,000
X/Y: 1.5KW/8NM
Z: 1.8KW/12NM
Positional accuracy mm ±0. 003/300
Repeatability mm ±0. 003
Usable area 1850 x 2530 x 2300 mm
Weight 3500 kg
IMMEDIATELY AVAILABLE
WITH SPINDLE OIL COOLER
COULANT TROUGH SPINDLE 20 BAR
Thank you!
- You may not post replies
- You may not edit your posts
Forum Rules
