Need guidance on upgrading from 3axis to 4axis
Results 1 to 4 of 4
Thread: Need guidance on upgrading from 3axis to 4axis
    Aug 2016
    Default Need guidance on upgrading from 3axis to 4axis
    Have a CNC with Richauto A11 3-axis DSP using DMA860H drives with a push button on the x-axis to do rotary work if needed.
    1. Aspire 9.5 claims to be able to do 4-axis now. Is that true?
    2 If true on Aspire 9.5, does it makes sense for me to upgrade to Richauto A18 4-axis DSP, add another DMA860H drive and rewire the push button to handle the c-axis?
    3. Would I need a reset switch for c-axis when doing the go to home position on startup? Not sure how this would work.
    4. Is there any recommendation of where I could get the DSP and drive in the US?
    Thank you in advance for any guidance I can get from the group.
    Sincerely,
    Asim
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Need guidance on upgrading from 3axis to 4axis
    Aspire does wrapped 4th axis, and has for several years. Version 9.5 just adds some new features to make this easier/more powerful.
    Sorry, can't help with the other questions.
    UCCNC 2017 Screenset
    Aug 2016
    Thank you for the clarification on Aspire 9.5. Starting point at least.
    Jul 2014
    Quote Originally Posted by afar View Post
    Wouldnt mind a "How to guide" myself. If any one could point me in the right direction it would be appreciated.
