- Looking for best suitable machine to poke holes in electrical enclosures
I'd like to get some input on what type of machine would best suit our needs, as most options that I can find are "too much machine" given this is mostly light duty machining with limited axial tool travel requirements.
At the same time, i'm not looking for hobby-grade routers.
One option i've looked at so far is the Rittal Perforex series, however this appears to be a 'one-trick' pony,
and i've not found 1:1 alternatives to compare both functionality and price-setting to.
Application:
drilling holes and cut-outs in electrical enclosures.
sizes 120x120x80mm up to 1200x1000x400mm, and flat panels sized 1800x800x20mm.
materials: PC, lexan, painted steel, and stainless 304.
conforming to CE is a requirement, and we'd prefer to buy new rather than 1980's used.
Hoping that i can get some more input or suggestions here!
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
