- Which mill out of two?
Hi
I am planning to get into CNC milling, and need to buy the first machine. I am stuck between 2, need someone experienced to help me.
1. Warco WM16B. It is basically BF20 clone I believe, something like PM25 or G0704, or
2. Warco GH18, also Optimum clone, not sure of the model.
Now, the benefit of the second one is that it is much heavier (190kg vs 125kg), sturdier, ways are much wider for almost the same price. But, it is geared (6 gears) and it spins to only 1450rpm.
Which one would you recommend me getting?
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
