Where can I buy a Taizi (Chinese) stepper motor
Results 1 to 3 of 3
Thread: Where can I buy a Taizi (Chinese) stepper motor
    Mar 2006
    Default Where can I buy a Taizi (Chinese) stepper motor
    I would like to purchase another stepper motor for my rotary fixture. The stepper motor that is currently on the fixture is made by Taizi, a Chinese brand.
    The marking on the Taizi motor is below:
    57BHH56P-560A-29
    Thank You,
    Roger
    Member awerby's Avatar
    Apr 2004
    Default Re: Where can I buy a Taizi (Chinese) stepper motor
    You don't have to buy the same brand of stepper; just find one with the same specs. What makes you think you need to replace it anyway? About 99% of the time, the reason a stepper doesn't work isn't a broken motor (unless you tried taking it apart). It's usually a bad driver, a faulty connection, or a mechanical problem.
    Mar 2006
    Thank you for the response Andrew.
    My current stepper does not have a problem. I'm looking for an additional stepper motor, either a Taizi 57BHH56P-560A-29 stepper motor, or one with the same specifications.
    I do not have the specific specs for the Taizi motor, therefore, if someone does have a specification sheet for the Taizi 57BHH56P-560A-29 stepper motor, I would appreciate a copy to help me find another motor with the same specification.
    Thank You,
    Roger
