- WANTED TO BUY FOR MAZAK QT 15 ANYONE HAVE SPARES ???
I am looking for a replacement motor connection junction box to fit a MAZAK QT15.
This is the alloy box that sits on top of the spindle drive motor and contains the associated motor connections.
Must be in good condition with little to no damage.
ALSO>>>> need a hydraulic valve solenoid coil. Have no part number, but the same ones are used for the chuck and tail stock hydraulics.
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
