Hardinge HC Turret Parts
Results 1 to 3 of 3
Thread: Hardinge HC Turret Parts
    Jun 2010
    Default Hardinge HC Turret Parts
    I just picked up an HC Chucker with the 8 position turret that I'm going to convert to CNC. Unfortunately it is missing the center turret shaft with the gear on the bottom and spline on top, the rod gear(helical I think) that is between the handle to rotate and lock the turret and the turret shaft, the bottom turret bearing and sleeve/spacer. It is also missing the 5C collet draw tube parts. It has a little hydraulic unit for the collet closer but nothing else. The taper is in the spindle.
    Anyone know where I can find these parts for a reasonable price?
    Thanks!
    Mike
    Feb 2018
    Default Re: Hardinge HC Turret Parts
    Hey there! I might be able to help actually. I work for a company that locates machinery/tooling/equipment/parts for free and for very reasonable prices. PM me or email me at machinerylistingserviceimp@gmail.com
    -Alissa
    May 2007
    Howdy, email me tom at 02Again dot com I have some chnc parts as well as a complete machine with a fagor control I will sell cheaper then you could possibly build one
    tom
