If you connected the encoder signals back to KFLOP (in parallel to the Amplifier) you could use our Step Response Screen to make plots and observe performance.
The other benefit of doing this is that KFLOP could detect following errors and after a fault the commanded position could be reset to the current encoder position without requiring a re-home.
Regards
