The rest... ive got a headache !What Size encoder is the perfect fit?
1. The Viper 200F Driver has a step rate of 300Khz. And a Max encoder frequency of 625Khz.
To run at 625Khz, you need to have a very noise free twisted pair setup.
Isn't your maximum speed limited by the lower of either the input and output count rates? In this case the 300Khz output?
Depends on the step multipler. With a 10X step multiplier , 65Khz step would give 650Khz encoder.
2. When using quadrature, is the 4x multiplier a result of counting 4 times as many points on the encoder wheel, or is it done in the driver after receiving the single count form the wheel? I.E. will quadrature multiply a 1000 line encoder and make it appear to be a 4000 line encoder (not in quadrature) and reduce the max encoder/motor speed by a factor of 4?
I recommend a 4X step multipler so 4x quad cnts are just used to increase positioning accurace, not as resolution
3. I also read that Mach3 has a max 100Khz output, and that parallel port is somewhere in the neighbourhood of 40Khz? Will something else be the bottle neck in the chain and reduce my motor speeds if I go for a higher line count encoder?
Am I reading too much into these different factors in determining the corrector line count for an encoder?
The PP can easily run 100 Khz. With a good terminated BOB. (All BOB's aren't made the same )
My aim is to have machine accuracy to 0.5/1000". I read that you want to have your encoder accuracy to be 5x more precise then your machine accuracy. I.E. 0.1/1000"
The encoder will be mounted directly to the servo motor shaft, there is a 5:1 pulley gear reduction to the ball screw which was a pitch of 1.847 inch/rev. The motor has a max RPM of 3000RPM.
The fastest speed i would want this machine to go would be 600ipm, doing the math that means the motor will only ever reach a max speed of 1624 RPM.
Thats fast for a 5tpi screw.
Larry K
