- Newbie- power up issues viper 200s
Try Reversing the power wires to the motor.
Sounds like the encoder is wire ok though because the drive trips with "excess encoder error"
thanx larry that did the trick. still kinda working my way through the motor tuning stages. confused about the jumpers. each drive has 3 seperate banks. each bank can be used for different motor configs? so for my motors i should set all the banks to number 1? what about the step multiplier jumper? not sure what jumper to set it to. thanx
- You may not post replies
- You may not edit your posts
Forum Rules
