Well done Larry, that's quite the little family you have going now.
What size machine do you foresee them fitting, benchtop, small router?
I've got a new addition to the Viper dive line. Its a very low priced small drive, the Viper 60 (baby viper).
The ratings are
- Max Voltage - 60 Volts
- Max continuous current 8 amps
- Peak current 20 amps
- Uses IRF540 mosfets
Its mainly designed for driving Keling style Size 23, 60 volt motors or Size 34 running at 60 volts. Since the continuous current on most 23 and 34 motors is less than 8 amps, this drive handles them no problem.
For economy the drive has a few less features than the larger drives, but still has differential encoder input, all the tuning features, and is very easy to connect.
So the line up is
Viper 60
Viper 95
Viper 100/200
Viper 250
Larry K
The Viper 60 will be available for orders at the first of November. Price is under $90 each
The delay was because i've been working changing my Starcam controller from printerport to USB for the last few months. I mostly sell CNC routers to Canadian Schools and had a lot of orders for CNC routers over the summer and they had to be USB.
The USB was a real challenge but its working pretty good now. ( I have learned the only good USB is an opto isolated USB !)
BTW, USB will probably never be on a Viper drive, RS232 is much better !
Larry K
Here is a picture of the little Viper 60.
The ratings are
- Power supply Voltage - 24-60 Volts
- Differential Encoder input
- Disable input with reset, with soft restart
- Fault output
- On board fuse
- Under voltage protection, Over voltage protection, software current limiting.
- Uses 22 amp 100 volt, IRF540 mosfets
- New Easy solder plugs and screw terminal connectors included.
- Perfect for size 23 and small 34 motors.
- Available with flat of angle mounting
Priced under $90 each (per 3 pieces)
When will the at least some description of the drivers themselves?
Although the connector pinout ...
I could not find a description of the site. Please give the direct link to the manual.
Sorry for the delay
Here is the PDF for the V60
http://www.viperservo.com/dloads/viper-manual_v60.pdf
I will be adding more soon.
Larry
Larry, is this drive still for sale? was just on the viperservo sita and did not see it listed.
Yes, but i havn't been advertising it until i get my pick&place up and running. It won't be long now.
If you want some let me know and i can make a batch (the old fashion way).
Larry
