Epoxy Granite VMC build (preview)
Results 1 to 4 of 4
Thread: Epoxy Granite VMC build (preview)
    Member ardenum's Avatar
    Nov 2020
    Default Epoxy Granite VMC build (preview)
    A friend of mine recently completed a VMC that doesn't require sending all the tonnage to machining after curing. Here's a preview. A full build video with BOM, pricing and CAD files of the project will come in the following weeks.
    He's a little shy, I'm hoping I'll convince him to register and share the full video himself...
    Jul 2010
    Default Re: Epoxy Granite VMC build (preview)
    He doesn't seem shy in his videos and the amount he is asking everyone to share his videos in the comments is crazy,
    I think this is you from the video again trying to get people to follow.
    I'd be keen to see an indicator run across the linear rails to see how good they actually are without having them milled to spec.
    Sent from my SM-G781B using Tapatalk
    Jan 2008
    Watched the video before.
    Pros:
    He made something
    Cons:
    Won't be nearly as good as he / others may think
    No effort to prepare rail mounting surfaces. Used a dial indicator to check parallel horizontally, but nothing otherwise. Rails will not be flat, straight, or free of twist.
    Pouring epoxy then stones in then mixing by hand...
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
    Nov 2020
    Quote Originally Posted by Momentz View Post
    Interesting theory but I would be using UHPC instead of EG and definitely not a VMC, not a fan of those...
