Mill/Turn lathe servo driven spindle drive?
Results 1 to 2 of 2
Thread: Mill/Turn lathe servo driven spindle drive?
    Jun 2003
    Default Mill/Turn lathe servo driven spindle drive?
    Hi All,
    I very much like the concept of the SwissMak and I'm interested in making a slightly larger and more robust version of it.
    My main concern is that I would like to use a large servo motor to drive the spindle but I have doubts that a timing belt would be an acceptable in terms of holding the spindle rigidly enough for milling operations. I don't want to use an inline direct drive because that would mean I could not put long stock in the chuck. I guess an option is an anti backlash split gear. Any thoughts on what may be a suitable means of driving the spindle?
    Splint
    Dec 2013
    Default Re: Mill/Turn lathe servo driven spindle drive?
    A belt drive in combination with a disk brake would work well. That's what my lathe has.
    Jim Dawson
    Sandy, Oregon, USA
