Yet another epoxy granite mill - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 101
Thread: Yet another epoxy granite mill
  1. #41
    Aug 2006
    Denmark
    Default Re: Yet another epoxy granite mill
    Another and cheaper option would be to just use some sort of leveling bolt, like this:
    https://uk.misumi-ec.com/vona2/detail/110300510150/
    ...and then put a seating plate below that:
    https://uk.misumi-ec.com/vona2/detail/110300510240/
  2. #42
    Member ardenum's Avatar
    Nov 2020
    My machine is very similar to this.
    https://sc01.alicdn.com/kf/HTB1wg1wO...XXXV.jpg_.webp
    or to this :
    https://www.facebook.com/VulcanMachineCo/
    Difference is the column guides are more widely spaced, and I got 2 ballscrews on there instead of one.
  3. #43
    Apr 2008
    Slovenia
    Quote Originally Posted by badhabit View Post
    With these guys:
    https://www.alibaba.com/product-deta...834288030.html
    ...haven't gotten them yet, so can't vouch for quality etc.... it is always sort of a gamble with these suppliers, but we'll see when they arrive...
    Have you maybe received them by now ? I'm wondering what kind of quality they have as i need them for my machine
  4. #44
    Aug 2006
    Denmark
    Quote Originally Posted by lukahr View Post
    Not yet, but they are on their way:-) Got an shipment-update from them yesterday, so maybe later this week...
    /Thomas
  5. #45
    Aug 2006
    Denmark
    They arrived a couple of days ago and today i had the time to unwrap them and have a look at what they made. I think i'm satisfied so far, they seem to slide very good and they seem sturdy. The "finish" is not "5 star" worthy, more like a 3-4 star, e.g. the welding and corner allignment is kinda....umm...."not how i would have made it"? :-) But i'm pretty sure it will do the job just fine... I've added a bunch of pictures, let me know if there is anything in particular you are interested in...
    Yet another epoxy granite mill-image-ios-21-jpgYet another epoxy granite mill-image-ios-20-jpgYet another epoxy granite mill-image-ios-19-jpgYet another epoxy granite mill-image-ios-18-jpgYet another epoxy granite mill-image-ios-17-jpgYet another epoxy granite mill-image-ios-16-jpgYet another epoxy granite mill-image-ios-15-jpg
    /Thomas
  6. #46
    Aug 2006
    Denmark
    Today the lasercut steel for the z-axis and cross table arrived. Lots of grinding and welding awaits:-)
    Yet another epoxy granite mill-img_0916-jpg
  7. #47
    Member Waynekofuco's Avatar
    Mar 2021
    Awesome, where did you source steel and cutting?
  8. #48
    Aug 2006
    Denmark
    Quote Originally Posted by Waynekofuco View Post
    Just a somewhat local company... ( https://www.staermoseindustry.com )
  9. #49
    Aug 2006
    Denmark
    Well, it seems like i'm "back on track" with the mouldwork again. I had a "minor" issue with my sheetrouter after i moved it to another shop... i forgot to re-align the two motors moving the gantry, so X-Y was not 100% perpendicular :-( This resulted in me wasting hours of milling and expensive phenolic plywood(~1000USD)... dang it! Well, lesson learned! Got it aligned perfectly, again, ordered the plywood, again, and milled the parts for the form, again... and this time the pieces fit together quite a bit better and the mould is square this time around ;-)
    I'm currently assemblying it (again). Here is a a picture of both the bottom(stand on it's end) and top form:
    Yet another epoxy granite mill-image-ios-23-jpgYet another epoxy granite mill-image-ios-22-jpg
    ...neither is fully assembled yet, but will be in the next couple of days...
    /Thomas
  10. #50
    Aug 2006
    Denmark
    Bottom mould is completly assembled now. All bare or sawn edges are taped of with releasetape and the mould is ready for a coat of releasefilm before mounting all the anchors:
    Yet another epoxy granite mill-image-ios-24-jpgYet another epoxy granite mill-image-ios-26-jpg
    I was in doubt how i should seal these ends, but ended using the tape. I did consider painting the ends and then wax them, but almost nomatter what i do, there will always be some sort of impression in the EG, either from the wood structure or from the tape. With the tape i at least know it will release very easy...and most of the casting will be covered anyways:-)
    I originally added ribbing on the underside of the mould to help support the mould and to somewhat isolate it from the concrete floor during the curingprocess. However, i'm not sure it helps anything now that i've assembled it :-)
    Yet another epoxy granite mill-image-ios-25-jpg
    The top mould is fully assembled, but i didn't manage to finish up the top-mould with tape tonight...maybe tomorrow :-) This is how it looks now, currently upside-down:
    Yet another epoxy granite mill-image-ios-27-jpg
    (Before anyone asks, this is the tape i've used: https://www.easycomposites.co.uk/flash-release-tape I've used it previously and it's nice to work with, sticks pretty good while still removeable and nothing sticks to the top side of the tape...)
  11. #51
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi All- Heres a video on mould release systems...Thomas looking really good....Peter
  12. #52
    Aug 2006
    Denmark
    Quote Originally Posted by peteeng View Post
    I've bought this together with the epoxy components: https://shop1.r-g.de/en/art/165105
    ... however, my experiments with the "phenolic plywood" and epoxy showed that there was no need for any form of release was/film. I made multiple tests: no release agent applied, only wax applied, wax+PVA applied, only PVA applied and all of them released equally easy(and quite easy in fact)... and since i'm taping off all bare wood i'm not concerned at all...So i'm only applying it just to be safe ...
  13. #53
    Nov 2020
    Beautiful molds, do you do woodworking professionally?
  14. #54
    Aug 2006
    Denmark
    Quote Originally Posted by ardenum View Post
    Well, thank you But no, i've never worked much with wood and this is my first project of this kind...
  15. #55
    Aug 2006
    Denmark
    Finally(!) done with all the steel inserts... around 200kg of drilled and tapped steel, ready to be sandblasted and then put into the moulds!
    Yet another epoxy granite mill-image-ios-3-jpgYet another epoxy granite mill-image-ios-4-jpg
    ...casting-day is fast approaching!
  16. #56
    Jul 2018
    dum dum
    Hi Thomas - Fatherhood takes time. When you get the parts blasted you will get flash rusting. Are you going to coat the parts immediately in epoxy? or touch up prior to casting? Peter
  17. #57
    Jul 2003
    california
    I tend to now use "Wet blasting" and put an additive in the water. Stops flash rust.
  18. #58
    Jul 2018
    dum dum
    Hi T4S - But that would probably be an oil? then it will interfere with the epoxy bonding to it? Peter
  19. #59
    Aug 2006
    Denmark
    My plan was to cast directly after the blasting. But since we are fast approaching the holidays and the schedule might slip, i'm considering getting the blasting company to apply a light "metalization" to the inserts to avoid rust. I think it's just hot-sprayed zinc, so i don't think it has a negative impact on anything(?) other than my wallet ;-)...
  20. #60
    Nov 2020
    how 'flash' is this rusting? Are we talking minutes? Coating in epoxy sounds like a good option.
