New Machine Build Vertial milling machine
Results 1 to 11 of 11
Thread: Vertial milling machine
    Sep 2015
    Default Vertial milling machine
    Hello, i work on some weekends on my first cnc vertical mill. The progres is pretty slow due to time and money. This is what i made so far. All parts still needs to be machined, squared and so. For the guides i have 25mm thk for the y axis. The rest for the z and x axis needs to be purchased, but i'l go with 25mm. Here are two videos with my progress so far. Thank you for watching.
    https://www.youtube.com/watch?v=U2Q_mJeRU6w&t=7s
    https://www.youtube.com/watch?v=B1kdXgYmyXk
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Vertial milling machine
    Hi Calin - Heavy metal is looking good. Peter
    Sep 2015
    Quote Originally Posted by peteeng View Post
    Thank you!
    Jul 2012
    Your 1 axis "surface grinder" is very cool
    Sep 2015
    Quote Originally Posted by jackjr-123 View Post
    Thank you!
    Sep 2015
    Making of a nut seat for the ballscrew nut with 3 jaws lathe.
    https://www.youtube.com/watch?v=dcubuhzYXu0
    Also, how can i post a ytb video here on forums?
  7. #7
    Member routalot's Avatar
    Dec 2003
    Quite easily,you copy the URL of the video and then click the icon at the top of the reply page that looks like a couple of frames of old style film,this brings up a dialogue box into which you then paste the URL.It is likely to appear in your reply as a bracketed piece of text but the magic of cyberspace will make it appear in your post.
  8. #8
    Sep 2015
    Hello, here is a video i made and i wanted to share with you where i have done a steady rest for the lathe at my work. Hope you like it guys!
  9. #9
    Sep 2015
    New little update, working on a bt30 spindle. Here is a video with my progress so far. Thanks for watching!
  10. #10
    Sep 2015
    Hi, i made a video of a cheap diy heat treatment owen wich is needed to heat treat my bt30 spindle. Thanks for watching, hope you like it.
  11. #11
    Sep 2015
    Hi, i want to share with you, just another lathe toolpost drill/mill attachment made by myself. Thanks for watching!
