Need Help! Let's build some ISO20 spindles
Results 1 to 7 of 7
Thread: Let's build some ISO20 spindles
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Let's build some ISO20 spindles
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Mar 2014
    Turkey
    Default Re: Let's build some ISO20 spindles
    It took some time to finish the first gripper because I was busy with other things but here it is. Jaws made from ck45.
    Sent from my MI 5s Plus using Tapatalk
    Suat
    Mar 2014
    Turkey
    And here I am on the design at the moment.
    Attached Thumbnails Attached Thumbnails Let's build some ISO20 spindles-1-jpg
    Suat
    Mar 2014
    Turkey
    What is the correct angle for ISO20 taper? I mean what the angle of the spindle taper should be?
    Suat
    Jun 2007
    canada
    um. shoudlnt that have been the first step here?
    taper for ALL steep taper type tooling, regardless of size is 7 in 24.
    which means, your profile reference points for angle are are 3.5 units radially, 24 units axial. with an opening of 22.225mm (7/8") diametre.
    wotzBotz
    Mar 2014
    Turkey
    Soo, does that make 16,5943?
    Suat
  7. #7
    Jun 2007
    canada
    i hope not. your tools will fall out.
    it should be half that per side.
    i assume you need the actual angle for manual lathe?
    wotzBotz
