On the base and z column, I would consider changing out the diagonal with a "W", there the bottom of the "W" is against the rails. The idea is that you have some longer unsupported sections, where you could get some significant machining forces, in some positions. The diagonal is fine for overall box strength, but you also need to think about dealing with point loads. Good luck!
