small mill project. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 46
Thread: small mill project.
  1. #13
    Jul 2003
    Holmen, WI
    Default Re: small mill project.
    Ran some oil through the saddle. Checking the flow. These are bijur flow regulators I got off eBay. I think they will work great. I slid the y axis on and it slides very easy on the film of oil.
    Sam
    (These are not made for 4mm tubing - but I found out the pressed in reducer removes easy. I just need to be careful that the tube doesn't protrude too far into the regulator - they don't flow then.. )
    - - - Updated - - -
    Things like this - the x axis stepper mount was getting in the way of the oil fittings.
    So - snip snip here and there...
    Getting things lined up pretty good. The really sucky thing is the table is slightly narrower than the saddle. (you can see the the ways and oil troughs) No one knows the story behind that goof. I plan on grafting an aluminum piece that bolts to the table to extend it over the ways. (mainly I want the oil to mostly stay under the table.)
  2. #14
    Jul 2003
    Holmen, WI
    Without going past the ways - it looks like travel will be 10" x 7-3/8" X 10-5/8" (XYZ)
    - - - Updated - - -
    1/2 done. Went suprisingly smooth...
  3. #15
    Jul 2003
    Holmen, WI
    This is going to work well to fix the table width/way issue.
    - - - Updated - - -
    Some quick tests...
  4. #16
    Jul 2003
    Holmen, WI
    sorry about the quality...
  5. #17
    Jul 2003
    Holmen, WI
    Looks like the nose of the spindle will be 3 inches above the table.. I think that will be just fine.
    Thank goodness for soft limits...
  6. #18
    Jul 2003
    Holmen, WI
    Going to re-use the z axis way cover. I needed to add a extention to the ways so the accordion wouldn't get caught.
    Another exciting video...
    some random videos of making the way extension...
  7. #19
    Jul 2003
    Holmen, WI
    The reason why I added the 5" Z spacer...
  8. #20
    Member dharmic's Avatar
    May 2015
    Lovely work, thank you for (1) remembering to document as you went - something I never remember to do until it's too late - and (2) sharing it with us.
  9. #21
    Jul 2003
    Holmen, WI
  10. #22
    Jul 2003
    Holmen, WI
    Time will tell if it will work....
  11. #23
    Member arizonavideo's Avatar
    May 2008
    CNC paint brush!
    youtube videos of the G0704 under the name arizonavideo99
  12. #24
    Jul 2003
    Holmen, WI
small mill project.
small mill project.
small mill project.
